Hi All,
At what point does a 240VAC installation need to be approved? Is it *only* when connected to the mains supply, or anything which is considered 'permanently installed'?
For example, if I was to use a car battery and inverter in the garage with the 240VAC lines 'properly' laid along the walls feeding plug sockets and twin-pole switched lights (a permanent installation) - would I need to notify anyone?
If I then ran some low voltage cables (12 or 24 V AC or DC) from a transformer in the house, along the garden wall and to the garage (providing a means to trickle-charge the battery) - would this alter things? I suspect not as the transformer would mean the supply was isolated from the mains... but best to check!
I'm aware of the capabilities of inverters, current drain, voltage drop on low voltage garden line etc - so this is more of a legal question than technical.
edit: I should add, I can't currently afford to run 240VAC from the house to the garage (armoured cable, cost of qualified electricians time etc) so this is my DIY solution to the problem - providing it's legal
Thanks,
Steve
Thanks,
Steve
