If the MD was prepared to give up the income from the Feed In Tariff and install a fairly simple load allocation system then his turbine would be able to provide power during a power cut during windy weather.The turbine then sees no load and shuts down after a time. The site therefore still has to maintain a backup generator. Trying to explain this to the MD was quite a task. When power is restored, the 11kV RMU is electrically switched, the turbine sees a supply/load and begins to generate again.
but what sort of AC source could you use to make it work?
But you wouldn't want them to.You'll probably find that the 'cheap' grid tie inverters that are used on 'domestic' solar installations are not capable of 'free running'.
You say that - but, provided there is voltage regulation, isn't it inherent in all inverters (indeed all 'power supplies') that the 'power output' will necessarily be determined by the size of the load (from zero up to the maximum it can service)? If, as with the grid, the load in 'near infinite', the inverter (or PSU) will, indeed, work 'at full power' (in relation to the source power available to it) but if there is a modest finite load, then voltage regulation will dictate that it runs at lower output (and input) power, won't it?That's not the same when supporting a local load - the load decides how much power it needs, not the inverter. The inverter needs to adjust its power output as the load demands. Inverters designed to be grid tied cant normally do this, why should they, they don't need to, they always run at 'full power'.
Indeed, that's a variant of what I have here. The generator supply feed dedicated rudimentary lighting throughout the house, plus a few scattered sockets (neither ever used with grid power), hence avoiding any change-over switching. The CH system (boiler, controls etc.) is normally plugged into a socket from the normal CU. Next to that socket is a generator-supplied one - so, if it's ever necessary to fire up the genny, one only has to move that plug from one socket to the adjacent one to get the heating going!Using a single plug and two sockets works far better. All stuff required in an emergency comes from a consumer unit it's self powered from a socket on the main consumer unit. In the event of a power cut you can unplug from main consumer unit and plug into generator instead.
When power is available power from the turbine is allocated to as much of the site as the available power can feed and the rest of the site is fed from the incoming mains supply.
Anyone heard how they are getting on with alternatives to batteries for storing power from solar/wind/etc sources? ISTR they were trialling something in Scotland using thermal storage, or hydrogen fuel cells...I know that using phase-change materials to capture and then release thermal energy looks to have a lot of potential.
