Hope someone can help.
I have a terraced house which has Intelocking concrete roof tiles. My problem concerns the underfelt which runs under the bottom course of tiles, just above the guttering to the side wall of the outrigger. Where the underfelt should drop into the guttering, it is perished and needs to be replaced. I therefore need to remove at least the bottom two courses of tiles, remove the fixing battens, cut back the old perished felt higher up to that which is not damaged, fix new battens, replace with new felt and reinstate the existing tiles. I've been up the ladder this morning and there is no play at all in any of the bottom course of tiles.
The existing tiles oversail the rear wall (pike) by about 25mm and have a 4)board underneath them which is about 6mm thick. In between the tile and the board is sand and cement pointing, which is all intact and in pretty good condition.
1) Is there a correct place to start removing the tiles and how do I get them out, assuming they are nailed in, without damaging them?
2) Are galvanised clout nails ok to use to refix the tiles in place. Should all courses of tiles which I reinstate be fully nailed and if they should, how do I nail the 2nd course, with the 3rd course already in place, lying over the top of them?
3)What spec of new felt should I use to replace the perished existing felt?
4) and just out of curiosity, what is the board that I mentioned above actually called and what is it made out of?
Thanks in advance for any responses.
