Morning all,
I have an existing johnson and starley gas warm air unit with a janus 3 gravity feed hot water system. The wau only heats downstairs with 4 registers (2 x living room, 1 x kitchen and 1 x base of stairs). The property is a large 3 bedroom terraced and the flooring is concrete.
This wau is now over 30 years old and spare parts (fan etc) are becoming increasingly hard to find and needs to be replaced.
If possible I would like advice on the following with regard to the pro's and con's of warm air versus radiators.
1/ Are the new range of j&s economaire warm air units a direct replacement for the old systems without the need for ducting realignment or metalwork.
2/ Is the hot water gravity feed integral to this or still seperate.
3/ Are the new filters as good as they claim (the old system does create a lot of dust and the wire mesh filters of old are not paricularly good)
And for radiators
4/ With a concrete floor will the pipework have to go up to the ceiling and leave a lot of unsightly pipework.
I have always been a fan of wau and would like to replace with same although must convince the boss who would like rads, although I would suspect price wise there won't be a lot in it.
Any views, advice or guidance would be greatly appreciated.
Regards
Dips
And for radiators
Regards
Dips
