- Joined
- 27 Jan 2008
- Messages
- 24,635
- Reaction score
- 2,816
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Not sure why you say nothing which is 'Smart' what have you against it? I have a few Tapo (TP-link) smart switches which do not require a neutral as they get their supply from a small battery, this means they are not affected by power cuts, it will not stop them switching on/off at the set times, and they do not loose the times set. They will work as a standard switch when there is no internet or hub, but they need the internet and hub to program them, and to correct the time from time to time.
They are just as happy switching 12 volt or 230 volt they don't care. Down side around every couple of years need battery changing, which can be done without removing the switch. The cover comes off to change battery.
I use them as they will not change state in a power cut, and can switch the power to a PIR controlled lamp, and don't need a neutral. They do need a hub and router to program them. While the hub and router is active I can control by remote button, or with voice commands using my Nest Mini speakers, as well as the mobile phone. I can control from the PC but the emulator takes so long to boot, I would never bother.
All my smart stuff has been selected as it will work with google Nest Mini's so although to program I have needed around 6 apps, once programmed in the control can be set so google home app works them all, this to me is a must as it is the way Nest Mini's control them with voice commands.
