- Joined
- 28 Jan 2010
- Messages
- 641
- Reaction score
- 75
- Country
Should I run a bonding conductor from the CU to the adjacent gas meter cupboard for the gas fitters to bond the meter and gas pipes?
Yes.
And don't use type C RCBOs, use type B.
Cheers TTC. Most definitely, judging by the standard of work I am having to fixDo you really think that you should be doing this work?
My plan is to follow manufacturer's advice and satisfy LABC for Part P inspection tomorrow.Its logical, not tacky.
If you have an all RCBO board then that's the only way to do it. You can then identify which functional earth is which.
What's your plan, stuff them all into the earth terminal marked "B"??
