its this n0 3 wire that don't tally joining the white.
and the red wire to n0 8 connector
the room stat is useally on the brown wire and the valve will close when you take power of the brown.ah ha it could go to the room stat as this would then give the signal to close the valve when desired temp has been reached.
The room stat is a dial and has a red and black wire feeding into it, also a single core wire. The other end of this single core wire comes into airing cupboard and connects into No 9 on the block connector.
