Hi Aptsys
It perhaps is due to so many different things being suggested that has caused a bit of confusion :d
The plan was initially to upgrade the CU to a split CU with no RCBO but dual RCD protection. This has for now been delayed due to the leccy not doing the work and then having to do further work.
So the RCD that you have suggested, will be used to replace the voltage breaker that is currently installed between the meter and the current CU which is a mix of RCBO and MCBs. The overall circuit at the moment is only protected by the VOELCB which I am aiming to either get board to replace with an RCD type or them install a breaker in the meter box so that I can then replace safely.
Then in a few weeks time, once I am ready, I will get the CU replaced.
