How do I fit the eaves trays? Surely they are under the laths?
Tomorrow I plan to strip the rest of the tiles, laths and felt and hopefully get some felt and laths down so it is a little bit weatherproof over night. I also have a bit plastic sheet I will nail down overnight.
I am also concerned that some of the wooden beams that the laths are nailed to look rotten at the bottom (where the felt was rotten). I guess more will be revealed tomorrow.
Sound like I am on the right track? Anything I have missed?
Cheers,
Mick
I've seen eaves tray fitted so that it fits over the lowest batten, but I've never been able to fit it like that. I've always fitted it so the lowest batten traps the eaves tray. This seems to create a dam at the bottom edege of the roof, but there shouldn't really be much water on the membrane.
The eaves tray overhangs the facsia by about 50 - 60mm, into the middle of the gutter. Obviously the membrane sits over the top of the tray, but doesn't need to reach to the bottom edge, otherwise there is the possibilty of it being visible when the roof is complete.
You'll probably find that you can fit your membrane in the same amount of time that it would take you to fit a temporary cover, so aim for that route. That alone will make it watertight. But also install at least every other batten to prevent the membrane disappearing overnight!
If you install only every other batten you may have to adjust the gauge when you fit the rest so it may be just as well to aim to fit every batten. It doesn't take long, if you have worked out your gauge and are prepared with spacers.
I've always installed the membrane with staples and then fitted the eaves tray under the lower edge, then fix the battens.
If you don't want to replace any rafters you can install a sister rafter alongside to strengthen it.
Edit: I suppose another method would be to install the eaves tray under the lowest batten, but allow the membrane to drape over the batten, leaving the lower tile to trap the membrane in that position.
