R
RedHerring2
I will trim my underlay so that it finishes under the cloak.
Any tips for applying the mortar? I suspect this is one bit I could make a real mess of!
I've always understood that the underlay/membrane should finish on top of the undercloak.
I've found the easiest way is from on the roof, working from the eaves upwards, obviously, with a bucket of mortar, just do the minimum amount of tiles necessary in each course so that you are always working from on the tile battens, until you reach the top.
Bearing in mind you may have to disturb any previously laid tiles for the adjacent ones to be positioned. So lay sufficient in each course that you don't disturb the verge tiles.
You may find that nailing the tiles tends to disturb the mortar, so that some tidying up is required. I have held something against the bottom edge of the tile before now to prevent mortar sliding down while nailing.
I use a mix of sharp and soft sand. Sharp for durability, soft for workability.
You can then complete each course later.
Of course, if you have two verges to do, you'll need to work out your tile spacing to achieve full tile spaces to be filled in.
