I’ve noticed in several recent threads references to need for a large turndown ratio, even to the extent of implying the system won’t work properly without. I’m sceptical and don’t think it makes more than a marginal improvement. The heat has to go somewhere, and generally things are most efficient at rated power - electric motors, IC engines etc. I haven't seen any figures for boiler efficiency vs turndown.
Cycling, in itself, has no great effect on efficiency.
The biggest problem. especially with Vaillants, is the requirement on (all) gas fired boilers to ignite at ~ 65 to 75% of full firing which entails getting the flow temperature right down to avoid the temperature exceeding the setpoint temperature by 5C which trips the burner and can lead to multiple refiring after the anticycle period(s), its not too bad if the burner is released to modulate say 10 secs or so after firing but Vaillants (used to anyhow) maintain the ignition settings for up to 60 secs, by which time the flow temperature has exceeded the setpoint by 5C leading to burner trip. Some boilers have a settable dT of up to 15C which would be a great help but it should surely be technically quite easy to increase this dT for a minute or two after ignition.
