These are not low voltage - just on a mains circuit. (FItted by previous owner who I call mr bodge-it for good reason)
All in zone 1 and I am pretty sure not IP rated - so I know are dodgy. I have screw in LEDs in them but think it is about time to replace them with something safer.
I thought I would have to fit a transformer/make them low voltage but reading around I think if I get some that are IP67 rated I don't need the transformer(s)?
Wiring is 'old' but I have a new(ish) MCB with RCD protection
So am I right?
Years ago I fitted them all with click connectors (after a nightmare replacing a broken fitting - I have access from the loft but even though the light fittings are in plasterboard boxes it would involve messing with rockwool insulation to get to them) so I should be able to replace them from inside the bathroom. I am planning on replacing them as the bulbs blow...if that sounds like an ok thing to do (not bothered about short term not matching and I would buy enough to do them eventually)
I haven't measured up yet but I think I will also need bezels or similar to cover up the fact they are likely to be larger holes than modern downlighters - where can I get those from? Ceiling is tongue & groove wood not plasterboard so not easy to patch (Not sure if relevant but size wise some of them took R63 bulbs and 2 of them R50 bulbs)
Many thanks in advance
So am I right?
