D
Deleted member 174758
Firstly the timbers used for this cladding are generally pressure treated in a fire retardant. Secondly, the steels themselves are coated with 3 layers of intumescent paint. Thirdly, the timbers are shot nailed to the steels. Fourth, with two layers of FR plasterboard and the joints fire mastic sealed it will take 2 hours or more for the temperature to rise sufficiently to cause charring of the timber. I have seen and installed this sort of fire cladding on a number of occasions in recent years - all the work was to architects drawings and was approved by the structural/fire engineers.It's not good practice to protect a steel beam with timber battens and board, if protecting a steel beam then steel angles should be used rather than timber battens. Or the fireboards can be screwed together around the beam.
