Wow, you lot have been active!
Henry1:
You state:
Incidentally, the insulation material you cram into houses is not environmentally friendly.
This would depend on what you use to insulate with. Try something like Warmcel (a blown, recycled newspaper insulation) and the energy required to manufacture it is next to nil. It is treated with borax, but it remains a comparatively green product. It insulates about as well as fibreglass so it is a fair comparison in, say, loft applications.
On a new-build, you could use straw bale wall techniques. I was originally put off by the very alternative associations this has, but have been won over by the technical perspectives, the durability of a very badly neglected and designed straw bale building I have come across, and the fact that the Germans have made some very presentable modern houses that you would not know are straw bale from their looks!
Obviously urea-formaldehyde foam insulation is a different kettle of fish, but if we consider the pollution from energy production, then the pollution created by the insulant might still be outweighed by the pollution saved by the energy savings.
If we had hydro-electricity here, maybe it would be better to cut down on insulation and use more electricity to warm houses.
There are greenies who would agree that we should heat electric, if this were coupled with a MASSIVE drive for carbon neutral (not biomass) electricity production. However, this would be based on an equally massive drive to reduce energy consumption. I used to work for a company that toyed with the idea of selling radiant electric heaters as an energy efficient and affordable means of heating, something I was very critical about. Staff who had tested the heaters at home reported that they were too expensive to run and would not heat the areas claimed, as I had predicted. In the end, the MD accepted that 'those heaters were a load of c rap', and dropped the idea.
I mention this as I have seen dodgy companies promoting much the same stuff on much the same grounds. They even point to a Historic Scotland refurb of a listed building and the fuel savings made. When I looked at the Historic Scotland website and the actual case study, as detailed by Hist. Scot., I saw this was coupled with a comprehensive insulation programme, something the electric heater pedlar had not mentioned.
We do have hydro here. Sadly, the only way we could increase our hydro production
significantly would be to flood our national parks. In any case, the C.A.T. does not really consider hydro to be particularly eco due to the large quantities of concrete used in construction and the fact that when a river valley is flooded, the usual practice is to leave the soil, plants etc under water. These rot in anaerobic conditions and so generate methane, a powerful greenhouse gas.
Insulation and draft proofing are the least sexy of the domestic eco technologies, but should take priority over installation of (often mis-sold) microgeneration. Of course, good draftproofing is easier said than done and not the simple bolt-on-retrofit the other technologies are.
You also mentioned that much of CO2 production is not man made. This is true. However, it is also true that the natural world tends to balance the CO2 it emits by rock weathering, and absorption into the sea, as well as the more obvious ways. Man does not balance his emissions.
Of course, we do not KNOW if anthropogenic climate change is a fact or if it is only a reasonable assumption (possibly as reasonable as the assumption that it is a myth). However, the problem is that our scientific method would normally rely on demonstrable and repeatable experiments with multiple identical planets, something not available to scientists.
(But my PVC issue wasn't particularly about CO2).
