ring main in concrete or wall?
how does a pair of 20A raidals use anymore copper than a 32A ring?
No, question is how does a pair of 32A radials use less copper than a ring?
you would only be installing 1 32A radial to match the capacoty of a ring
and yes it may use more copper to put in a 32A 4mm radial than a 32A 2.5mm ring depending on how far you are from the CU
but i really can't see the problem with using 20A radials for sockets and doubling the number over 32A rings
you save on the cable and get better segragation and avoid the spurring rules for rings
I'm a newbie to this forum and have been browsing so I may be responding to stuff you regulars have left way, way behind. If so, please forgive me.
If I understand it correctly, the original poster clarified that he was only planning to use conduit for drops, not buried in the concrete o the ground floor. That was a relief.
I've recently done a kitchen re-fit in my house, also a concrete/bitumen ground floor. The original electrical installation had been upgraded (or should I say 'upgraded'?) some years before I bought the house. To feed power to new ground floor sockets, a 3/4" conduit had been buried in the kitchen floor and 7/029 T&E cable run through it. I wanted to add some new feeds along the same route and initially planned to remove that conduit and replace it with a 25 mm one (for reasons I won't go into here, it wasn't feasible to go 'up & over').
Checking the regulations and guidance manuals, however, I was reminded that such a buried conduit (with both ends effectively pointing upwards) is a condensation trap. So I changed my plans and went for MICC (aka 'Pyro'), including the original circuit. Sure enough, when I removed the original conduit and cable, staining on the cable sheath and corrosion on the conduit interior confirmed that the conduit had spent much of its life at least half full of water!
As far as the original poster's conduit drops are concerned, nobody mentioned that they should be bonded. I agree that they should be bushed into metal boxes at the bottom (i.e. socket or switch) ends. Just for completeness, how would folks finish them at the top ends, up there in the floor/ceiling void?
