Hi all,
I've just moved into a new build and have had a few problems with the room stats not working. They have been replaced and now operate but there is still a fault somewhere. I have given up hope with the plumber and would like to fix this problem myself.
There are two zones, upstairs has radiators with wireless honeywell room stats and downstairs has under floor water heating using a wired honeywell stat in the lounge and a danfloss wired stat in the kitchen. All the stats operate regardless of what the programmer is doing, even if off the stats still work. The plumber had a hard time wiring the lounge honeywell stat because I think it was for 3 wires and the lounge had 5.
Either way, he got it working eventually but its not right due to the programmer not doing anything. What do I check, seems like the programmers outputting a constant live and never switching? Any advice appreciated as I dont want the plumber out again, he blew a thermostat and the programmer trying to install them incorrectly!
Programmer is a danfloss TS715 si, it will set up correctly etc and appear to work but physically doesnt shut off the stats.
Cheers
Cheers
