Metal stud walls arn't too bad, ban... as the OP alludes to, they are very often free of noggins so retro fitting is quite easy.
Yes, modern houses are thrown up quickly, but is what is produced any worse than owning on older property.
I've got a bungalow built in the late C19th, yes I've got solid stone walls, but I've also got a 1970s flat roofed extension that leaks, woodworm damage, inefficent 70's boiler, re-wireable fuses, sections of lead cabling, etc. I suppose there are advantages to having a new place that is energy efficient already doesn't need major attention to anything, just has some walls that sound a little flimsy - It probably wont last 100 years, but then again that will be someone elses problem by then!
