Hehe
plstering earlier today!
Can't help but feel that somehow, my thread has been hijacked...
To trading standards?i was just trying to help the guy out the pics are of my work and trust me all the pople i work for are more then happy to pass my number on
edit
although the dark stuff around the ends of the beam does look a bit strange.
Just to get this back on course. The fact is nervous, it's not easy to see from the photos. On the face of it I can't see a lot wrong although the dark stuff around the ends of the beam does look a bit strange.
What you need to check are the bearings. Is the beam sat on brick/block masonry or is it a concrete padstone. What's the plan for the walls beneath the bearings - how much wall is due to be left in place and how does the builder propose removing the rest? I presume whoever designed the structural beam has checked the foundation to make sure it is adequate.
Agreed. There isn't enough information to know anything for certain.
Good point about the foundations...especially if shallow as the load won't spread back through to the ground below.
Anyway...you need to firstly get the calcs that have supposedly been done, and if you can't get them, you need to expose what's there and see if an engineer can prove what's there to be adequate. The engineer might want to expose the foundations...which would be a real pain...
Why do you not want to involve Building Control? It's only around £150 for minor works such as this, and you will get a completion certificate that will be very handy when if sell in the future. If you don't involve them, you can't be sure the work has been done to their satisfaction and might cost a lot more when you sell.
Yeah, but if the footing are shallow (250mm or less in old houses) the load isn't going to spread far back along the existing footing, so is concentrated on the ends. Sometimes a stiff base beam is put in below floor level to spread the load back along the existing footing.Surly there is adequate foundations as from looking at that photo i think there used to be a wall there where mr builder nocked a great hole through, then placed in a steel to support the upper floor.
Without the calcs can't say if padstones are required, although would always specify them...could be an engineering brick under all the gunk I guess, although might not be enough either...Would of liked to see some pad stones but can not tell clearly from the pic if they exist.
Well, because it's a legal requirement, ensures compliance with the building regs (which are there for a reason), and will prevent a whole load of stress if and when the house is sold...Why would you? Unless you have not got a clue on what you are doing :s
