- Joined
- 27 Jan 2008
- Messages
- 25,373
- Reaction score
- 2,985
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The auto transformer is the normal method however the created new neutral will not be a true neutral. Seem to remember there was also a wound unit called a reactor I have many years ago used them to get a centre tap without using the earth for radar units in traffic lights. Basic design is a transformer star winding but the secondary is not used. It is so long ago I can't remember the calculations for size.
In the main they are used where the supply is from a delta transformer or generator to get a earth. If I needed one I would need to call in a specialist as this is so unusual.
I think my first call would be to a rewind specialist and ask them for advice. You come across many strange systems working abroad including running an old motor with large flywheel with a star winding and using the star point of the motor to get the false neutral. In the UK I would simply swap motor for a 3 phase one.
