Safe use of a spur
24 Mar 2012
Lancashire
Hi experts. I just bought a new electric kettle, which is stated to be 3000 watts (3 kilowatts). When I ordered it, there was a misprint or something of that nature, in its description, and it said 300 watts (yes, I checked this very carefully before ordering, because I wanted to play safe). This kettle is now in use, and seems to be OK. However, on this wall (above the worktop) in our kitchen, there are several plugs, and they are all powered from a single spur. The house ring-main has two 2.5 squ. mm cables to each terminal of each plug (I think that this is the calibre of these cables), and it is from this ring-main that the spur comes.
The maximum demands on this spur (if all appliances were used at once) would be as follows: 1 Bread machine (545watts, used only every other day for about three hours), 1 under-counter fridge, 1 under-counter freezer, a small transistor radio (hardly ever used), and the kettle.
It am concerned that this kettle could be too powerful for the supply along the spur, and the spur might get over-heated, or burn out altogether, in time. However, I don't know for sure. Can someone please advise me?
With thanks for any helpful responses,
A.W.
It's not technically compliant.
A spur with more than one socket should have a 13A fused connector unit to limit the current.
However, with 2.5mm² cable it could have a 27A fuse, but there is no such thing higher than 13A.
It will be fine with the appliances you mention.
Thanks very much for that, EFLimpudence; also, for the promptness of your reply. This spur, and the house wiring as a whole, was installed by an electrical engineer nearly forty years ago. There is no fuse on the spur. Perhaps the regulations were not as strict as they are now, since he provided us with a certificate for the rewiring job. As far as I am concerned, what you imply about there being no risk of burnout is enough for me. It would cause tremendous upheaval to fit a fuse, so it's a great relief to know that its safe. Thanks again.
Regards,
A.W.
The 14th Ed. was in force in 1980 and actually was usable up to 1985.
Regulaton A40 says:
"..........Not more than two socket outlets, or one twin socket, or one stationary appliance, shall be fed from each non-fused spur."
So, two single sockets on a non-fused spur would have been compliant, but no more.
Regulaton A40 says:
Yes, I take your point, Securespark. The engineer must have known that the job was not pukka. If there is no danger in practical terms, I am satisfied. I just did not want an catastrophic expense to ensue from using these appliances, or any danger. Thanks for the information!
Regards,
A. W.
They are sockets not plugs and there should only be one on a spur.
Plugs are the bit on the lead which goes into the socket on the wall.
Hey, that's an irony! Frequently, I correct others about this wrong use of terms, and got caught out myself.
Regards, A.W.
