Salus EP200 CH ON when only HW ON
28 Feb 2015
London
Hi everybody and thank you for posting such good and useful informations.
I settled in UK few weeks ago and I'm experiencing an annoying problem with my Salus EP200 controller:
When I turn on the CH then the HW turns on while the control panel HW LED is always off, in the same way when the HW is switched on then the radiators warm up while the control panel CH LED is still off. :?:
Please, sorry about my bad english and my lack of knowledge on the plumbing and central heating matter.
Thanks in advantage for your attention and all your assistance.
Hello :)
are the jumpers on the back of the unit set correctly?
you can switch between pumped and gravity fed systems, if you have a pumped system then it will let you control them individually, if it is gravity then you must have them both on together.
of course they should be set to which system you actually have installed !
Take salus off the wall,go upstairs and chuck out of window onto concrete if poss.
Then buy a decent one.I would never use again
Hello :)
Thanks for the reply nerox.
The user manual says: «In fully pumped and controlled systems (jumper P), the central heating and hot water can be operated independently, but with gravity fed hot water systems (jumper G), the central heating cannot be operated without hot water.»
It should mean that with gravity fed system, HW should operated with CH off... or not?
Thanks dazza87, I'm still LOLing!!! :LOL: [/b]
