Samsung ue65nu8000T not powering up
30 Mar 2015
Can I get some advice with this please.
I get no sign of life when I switch this TV on. I’ve tried holding down the power button in various fashions but that hasn’t booted it up. The fuse on the plug and socket are fine.
I’ve opened it up and have this:
I’ve put my two pole tester on the fuse next to the power inlet and a bunch of other fuses/capacitors on this board and all have continuity.
Except, this green “thingy”, to the right of the fuse. When I put the probes on each leg, there is no continuity. Should there be?
I then switched in the TV and used my contactless tester (I appreciate it’s not a great tester) but this shows power on the power supply board and the main board too.
I then disconnected this cable going between the two boards and powered up again
I read that this may bring the backlight to life. Not for me :(.
Have I got a dodgy power supply board or is this way too inconclusive? I would welcome your suggestions on how to resolve this.
Thanks in advance.
The green 'thingy' appears to be an NTC (Negative Temperature coefficient) thermistor - a device that decreases its resistance with increasing temperature.
There may not be 'continuity' across the NTC, but there should be a measurable resistance - maybe around 10KOhms at room temperature?
Can you check resistance with your tester?
...and just looking closer, the power PCB was manufactured in 2018.
Samsung offered a free 5 year extended warranty (with registration), on some TVs.
How old is the TV, did you register an extended warranty?
Unfortunately, not covered by warranty. I did call Samsung. Good shout!
I have a 2 pole tester and a megger MFT. Would either of those help @RandomGrinch?
I’ve seen that a new power supply board is around £40 and they seem straight forward to replace. Will await some more advice before I take that punt.
Thanks for your help.
What makes/models?
Although the question then becomes, if you do find a dodgy component, do you have the soldering tools to swap it out?
At least it may prove that the board has failed.
It may be worth a gamble, you could probably put it back on eBay if you didn't get anywhere?
If I was you, I'd buy a new TV.
Wrangling around power supplies is dangerous especially if you don't really know what you're doing.
What makes/models?
Fluke T130 for 2 pole tester and megger MFT 1711 for the MFT.
That’s what I was thinking. It would be good to validate that the board is faulty. I can then swap the board out.
Happy to get the board if there is a realistic prospect of this being at fault based on the info I have shared. Appreciate it’s not guaranteed but didn’t know whether my information is just way too inconclusive to make that leap.
Thanks again.
