Scantronic 10n-16 Wireless Burglar Alarm
Set the garage pir attributes up as a "Final Exit". This way, when you open the garage door, you'll start the entry timer and you can unset the alarm with the fob.
You're not supposed to be able to unset the alarm from outside with the fob. This stops you from accidently unsetting the alarm as you put your fob in your pocket when leaving.
Okay, I checked it out today... From Installer Mode > System Options > about ten clicks down to Remote Needs Entry (or something like that) and disable it. I looked it up on a customer's i-ON30... i hope yours is the same!
Set PIR to Final Exit - didn't work and set the alarm off, upon entering the garage and pressing unset on the fob! Have set the PIR back to "Normal alarm" again.
I have now set the system to 'Remote Needs Entry' via the Installer Menu (yes I did have to press a few keys to get there) and will let you know tomorrow as I haven't had a chance to test it yet.
Really appreciate your help, thanks!!
EightyTwo>>>> Fantastic....Remote Needs Entry works!!! Thank you so much for your help, it is much appreciated.
