- Joined
- 3 Sep 2005
- Messages
- 34
- Reaction score
- 2
- Country
My electrician has advised me of the following for a rewire :
Hager Split load Consumer Unit 18 way.
Earthing system is TNS and the electrics are 1960's except for the earthing which was updated from TT to TNS about 10 years ago when a new ring main for the kitchen was installed. Even though it is only about 2mm thick!
Consumer Unit as follows :
RCD circuits - 4 32A ring mains (3 downstairs & 1 upstairs)
Non-RCD circuits - 4 6A radial light circuits (2 up & 2 down)
- 1 6A for Smoke alarm circuit
- 1 40A Circuit to garage separate 2 way CU inc RCD
- 1 16A Immersion Heater Circuit
- 1 6A for Bell?? Maybe use separate transformer?
Hager only go from 12 way straight to 18 way split load supposedly - so rest are spare ways for future upgrades - outdoor socket / garden lights / supply for pond pump - when the garden is done up.
The question I ask is that many people are advocates of RCBO's and they haven't been mentioned by my electrician, only standard mcbs with some on the side of the main RCD.
Is it best to use a standard CU and use RCBOs on the ring mains or just stay with split load and mcbs with some RCD protected???
Electrics need to be done quickly as the lights have no earth and some of the sockets blow the fuses when you plug anything in - also there is no earth bonding on pipework !!
Any help appreciated
Shady
Shady
