Hi guys, i have been trying to get a clear picture on this from reading other posts but not found an answer on this set-up specifically, so any help well appreciated.
I have a gravity vented system with a whole house pump on both hot and cold and located next to the cylinder. Due to the length of pipe runs , furthest away taps take over 1 minute to get hot water to them even with this pump. (It's a long bungalow that has been extended in both directions, pipework running round the eaves, the cylinder downstairs and an upstairs bathroom at the far end) Can i add a secondary hot water circulation pump also ? and if yes then i'm really after a clear description (or schematic diagram) showing how to configure this. I cant get my head around how the secondary pump would run without activating the primary pump. Many thanks, Steve.
