- Joined
- 27 Apr 2008
- Messages
- 9,751
- Reaction score
- 976
- Country
Combination padlocks are notorious for being easily decoded, any bank that uses these ought not to.
If not decoded using the old pull on the shank trick then a simple shim down between the numbers usually allows quick decoding if not complete opening.
The same goes for many padlocks, unless you spend some serious money on them they are a small deterrent at best.
Thus it would be adequate enough to fit a triangle lock albiet the key is available at most supermarkets they are simple enough to prevent the casual bypasser/child opening them.
