No, it's to protect people.
Don't get it EF. Can you enlighten me? Don't forget I'm a layman learning.
If I touched the brown sleeve of a live (I'm not going to experiment) would I get a shock?
If so, bllody hell, if not then how does leaving the outer casing on protect people?
That's always been the same. Not changed.
Not many bathrooms are big enough to do it.
Oh right, I read this and assumed that before 2008 sockets were banned full stop.
The 17th Edition, published in 2008, introduced a number of amendments. These included changes to the zonal system, RCD protection on all bathroom circuits, and 230 V socket outlets permitted 3 m horizontally from the boundary of zone 1
That's the way the system works, always wear your ppe and go safely home every night, rather than being in A&E.
Sorry m, that makes zero sense. Unless you really believe that a hard hat is going to protect me when I am above all works being carried out below? Unless a 'rule' makes sense then those of us with 'common' sense will question said 'rule'. It's a bit like a new recruit being told to polish his boots by a sergeant even though he's just cleaned them. Some will do as bid, others will tell him to f%@k off.
On the same site I was told there was no eating or drinking except in the designated areas which happened to be at ground level. It was summer and I was four floors up. So, I'm using gas guns and hot bitumen. If I need a drink I have to climb down four lifts of scaffold, have a drink then climb back up. By the time I'm back on the roof I'm thirsty........... you get the picture. Common sense is safer than listening to the clowns that have never lifted a hammer.
It is, provided that the socket you are intending to install contains an isolation transformer.
Ya it does,
Screwfix.
Given the nature of your reply, I doubt it is.
I was being ironic, and breath!!!!
because I know you've made a mistake and I don't want to name a figure that would be difficult for you to afford.
And the reason for asking questions on such forums is to glean knowledge If I've made a mistake, educate me instead of talking riddles
I'm looking at my board and I see a 6A fuse. It has a switch that if I sneeze too hard flicks off,is this not RCD? Did I mean MCB?
