Hi all,
Having read the topics on extending a circuit to a shed, I was wondering whether it would just be possible for me to run, what is essentially, a very long extension? Similar to the standard extensions you find, could I just extend the wiring to 10 metres and have the sockets built into the shed and the plug attached into a socket that's already 32amp RCD protected at the house/supply end?
I'm only just competent enough to wire up sockets and thought that this would be a cheaper, and legal, alternative to dangerously messing with Part P regulations. I intend to bury the cable underground (around 2 feet) in conduit for protection; I also toyed with the idea of running it through an old hose pipe for further insulation - is this wise?
So, do you think this would work? I can't see much of a problem as we have a 20 metre extension reel so why not just have a permanent 10 metre one? Any help and advice that you could offer would be greatly appreciated! Thank you...
John
John
