shed yes again lol
22 Oct 2009
Lancashire
can i use floor boards for the sides ? ive used ship lap on it and it has just swolen and bowed out it was treated with 3 coats of creosolt the wood has split around the screw heads and it was fitted correctly when i made the shed its not lasted a year :(. i thought of using feathered wood but as the shed makes 2 sides of the fence it needs to be thicker to stop the little s***s round here kicking it in any ideas?
you only ever have one fixing across any exterior boards to avoid splitting just place it 25% from the top or bottom pinching the next board underneath if nesisary
you also need a 3mm expansion gap[assuming txg] if below around 10% moisture
