Ok Im working on a large BBC site where there are about 10 3phase boards (hand made boards, mcb's on din rail) each board is backed up by a 250A switch fuse.
Basically there are 2 isolators in each board, essential circuitrs and non essential, there is a 70mm SWA supplying a 250A isolator in each board and they have linked out of the blue phase up to another 100A main switch for the non essential stuff.
The red and yellow phase are for the essential stuff, what they've done is instead of busbars they've run wires from the 250A isolator to feed the mcb's. However on the yellow phase the mcb's are indvidually wired back to the isolator in 4mm singles.
Im only working on the blue phase adding a couple of circuits, but should I connect them. My first reaction was im not connecting it but they insist I do and my boss agreed we would, but put in writing our concerns - Im not sure he's right on that?
They have agreed there are some issues regarding the boards but basically told me I have no right by law to stop the installation, I should connect the circuits then put my concerns in writing. If nothing gets resolved then I disconnect the circuit.
The maintenance electrician then said there's nothing wrong with feeding the mcb's from the main switch (100A) in 2.5mm singles as long as you don't have to much load
