Hi there,
[First post - comments gratefully received] I am about the remove tiles and strip plaster board in my bathroom. One of the walls to be stripped has an electric shower on it.
Therefore I have a couple of questions:
1. The cable runs from the loft (above insulation) down inside the stud wall to the shower. When I remove then refit the wall and shower can I upgrade the cable to the next size up so that if in future I bite the bullet and run thicker cable right from the CU I can install a higher rated shower without removing tiles to get at the buried cable?
2. from initial inspection by poking at holes the wall seems to have loose fibreglass insulation packed into it (I presume to reduce sound transmission?) When I replace the wall (with aquaboard) should I replace the insulation also? I don't think that the current 6mm2 cable would be sufficient for the current shower (9.5kW I think) when embedded in fibreglass in a stud wall.
3. I can't see any obvious earth bonding on the shower supply pipe (I know the mains supply is bonded well at the main stop cock under the kitchen sink) where should water pipes be bonded. Its mostly E/F soldered connections - does that make any difference. If I do need to do bonding, can I bond to a ring or lighting circuit? Would feel wrong, but I don't know why it wouldn't be safe!
Thanks for reading,
Chris
Thanks for reading,
Chris
