Thank you all for your comments, an amazing response! I will consider the insulation situation once I get the plasterboard off, but will likely upgrade the cable that runs to the shower.
The thing you refer to as the "shower pull switch" is actually a double pole switch in the airing cupboard outside the bathroom. The cable from there runs to a junction box (similar to this: link) in the loft, and from there down into the wall and to the shower. I would expect to replace the section between the shower and the junction box. Does that sound OK?
On the earthing/bonding/equipotential side:
There is a single RCD for the whole of the CU for all circuits in the house.
The bathroom also contains:
1. heated towel rail, taken from a fused spur run through the wall.
2. a non IP rated light fitting on the ceiling outside zone 2
3. a fuse box (the type that would normally be fixed to the wall) that is under the floor boards that runs some switched recessed lights in the kitchen ceiling below.
4. A radiator
5. A number of other central heating and mains cold and DHW 15mm pipes under the floor boards that run to other rooms, including those that run to the basin.
6. A shower.
7. A shower head riser bar - to mount the shower head on, plus a shower curtain rail.
Which of the above metal items should be bonded together / or to earth? As an aside I am also going to be running to the bath two new copper pipes from a pump outside the bathroom (driven from a different ring). It has plastic connectors, so the new pipes cannot be bonded to anywhere. That's not good is it?
Thanks again,
Hilme
4. A radiator
6. A shower.
Thanks again,
Hilme
