Hi guys,
Great forum! I'm hoping someone here can help me out? It first has to be said that I know nothing about plumbing...I'm a computer tech.
I bought a shower from B&Q...the innocence P shaped enclosure with shower tower.....it has hydrotherapy jets on it. I was told, that on a gravity fed system (which I have) all I would need is a pump to increase the preasure (1.5 bar min needed to run the tower).
I have now had 3 different plumbers in to quote for fitting, and 3 differing opinions on what I need to run it!!
One says I need to change to a combi boiler.....one says I need to replace the whole heating system with a sealed system???? The other says I need to install another tank to feed the shower seperately.
This is fast turning into an expensive nightmare!!
So, is there any way to fit some kind of inline heating device between the cold mains and the shower....some sort of instant heat thing like on electric showers?? If so, where would I get one?
Is it possible to use the unit from a power shower and rig it to the shower tower? I have a gas heating system, but don't mind using electric to run the shower.....it sounds cheaper than a new system!!
By the way, I'm in a bungalow, hot water tank is in the loft, so I can't get it any higher to increase the preasure. Mains on street is 3 bar, and in house just over 2 bar, if that's any help.
If you need any more info, please ask, as I'm not sure what you need to know to answer the questions.
I would be very grateful if anyone could shed light on this for me, I'm at my wits end.....I'm going to take a laptop to bits & repair it now....IT'S EASIER!!!!
Thanks.
Thanks.
