i've just moved into a house, the shower has no rcd protection, it is 8kw, it is fed with a 6mm cable, which is 9metres long, the cable runs into the loft and is pinned above the insulation, then down the house wall in plastic conduit to the consumer unit where it is connected to a 40 amp mcb. My plan is to break the cable run in the loft, and connect one of these :
http://www.ebay.co.uk/itm/CPN-ECU04...ectrical_ET&hash=item2569b9bbdb#ht_2335wt_932
is this a good plan ?
