Hi all again.....
I posted a topic a while back about my shower unit tripping it's MCB. This issue was fixed by an electrician at the time but now I seemingly have another problem.
It's a Creda 10.5kW shower unit fed by 12m of 10mm twin & earth cable, fed by a 45Amp MCB. The cable runs through the floor void between the ground and 1st floor without any insulation.
I was using the shower this afternoon and it just switched off for no reason at all? The MCB had not tripped and the neon light on the isolator switch was still on as well (as would be expected as the MCB had not tripped).
After leaving the shower switched off for a few hours, I tried switching it on again and it worked again? What could have gone wrong with the shower unit?
Just to add, it's a Creda Advantage 550C
