Having taken on board the advice here I am now going to use pyro for the lighting circuits in the loft area. This will increase the cost and time involved but will be the best method in the long term.
As a matter of interest (I've never used pyro), how does one deal with the terminations in a domestic lighting circuit (switches, light fittings etc.) when wiring is in pyro? Does one have to use JBs of some sort to convert to T&E, or does one attempt to terminate the pyro in the fittings/accessories?Having taken on board the advice here I am now going to use pyro for the lighting circuits in the loft area. This will increase the cost and time involved but will be the best method in the long term.
Ah, I see - thanks. That presumably means that one needs to create a reasonable sized hole adjacent to the backbox (if it's in plaster/masonry)?pyro to the fittings..
terminated into couplers on the backboxes so that the end of the gland does not protrude into the box..
Why is that needed?pyro to the fittings..
Can you get brass couplers?
The termination to ceiling roses is not as complicated as it seems. Provided the cable is clamped to prevent movement a screw on pot with earth lead inside a metal enclosure is sufficient in those applications where the installation does not have to survive a fire
The "joists" are very old round timbers just large enough to support the original lath and plaster ceiling. It is un-likely the joists will safely support the weight of a person. So work above the ceiling has to be limited to that which does not require a person being there. Conservation means the absolute minimum of disturbance of the ceiling.fitted to a batten fixed between two joints,
