Wonder if this has any relevance? I know the Plant Boys have been talking of issues with Red Diesel, which made me think... Red diesel: The problems uncovered - Farmers Weekly (fwi.co.uk)
I will have a read. Thanks.
For what it’s worth, I’ve found those water detecting pastes fine to detect pooling water but made no difference at all when trying to detect a water emulsion.
Good luck with it Tom!
John
I think that’s a good analysis - the additives are there to prevent this happening in the first place.
Early diesel cars had heated filters - either by water or electricity- to prevent exactly this.
These days, cars need a fuel cooler, as the pressures are so great!
John
The crystallisation causes havoc with fuel filters and the fuel injectors, which is spraying high Pressure fuel via almost microscopic nozzle.
These engines have 2x pre-filter and 2x main filters and it still causes issues.
Try the additive.
As a mechanic, I’d be more tempted to suspect that the blocked filter will drastically reduce or stop the fuel supply to the boiler. Nothing should get past the filter.If it is not the filter then I am back to square one, but my assumption, or at least hope, is that once the filter can no longer filter particles out the fuel passing through it will pick up deposited gunge and carry it in train to the pump and through to the nozzle, where the nozzle filter, which is new, duly filters it out, but in such quantity that it quickly becomes clogged itself. Sound about right?
An engine has a bypass system in case of a blocked oil filter as it’s for lubrication. Even unfiltered oil will provide better protection than no oil. There’s no bypass on air or fuel filters though - if they block up, nothing gets past and power drops or stops!Ok, well that's interesting, and a bit disappointing. Odd though because an oil filter in a car can get seriously gunged up without impeding the flow of oil (as far as I know). I realise we are talking engine oil as opposed to fuel oil, but the paper filter is essentially the same sort of thing, even if with finer filtration.
at any rate, the heating oil was making it to the pump with sufficient flow to run for 24 hours or so each time.
Fuel is a different matter to oil on an engine. I've been in and around drainage for most of my working life, and used a lot of the machinery involved in it's installation and cleaning. The vast majority of which run on diesel. Oil filter are designed to remove contaminants created by the engine, (you always put clean fresh oil in), and the same oil is circulated until such time as its changed and replaced with fresh.
Fuel is a completely different matter, it is consumed, in varying quantities, depending on size of the engine. Diesel supply systems on most engines have a water separator and several forms of filtration to remove the tiniest particles of muck. (It takes very little to wreck an injector pump.) When these filters block up, then fuel starvation occurs and usual symptom is a loss of power.
