True, provided that one has complete faith in the fact that main bonding for other extraneous conductive parts is present, satisfactory and will never be removed. If you don't have that faith, there is a possibility that what you will have is a Faraday cage which, for example, is pervaded by earthed earthed gas pipework - which would be less reassuring! Admittedly, there will normally be an implicit connection between gas and water pipework (usually at a boiler), but even that is not guaranteed if some of the water pipework is plastic (or there is no gas boiler).In the case of a lost DNO earth, ot a TT earth or a PME lost neutral/earth, followed by a live to earth fault (except in the PME case where normal conditions will affect it) think Faraday Cage, that's all it is about!
Kind Regards, John
