Smart controller wiring
8 Aug 2005
Sussex
I have a bunch of smart controllers from Shelly designed to sit in the back of a socket backbox. Some have a rating of 8 amp, some 13. I wanted to use them to switch and monitor consumption of a bunch of 3D printers, one per socket. I have a 6KVA UPS being installed using a 16 amp radial input from the Consumer Unit and output as 16 amp radial also. My confusion lies over the rating of the smart controllers, neither are rated to 16/20 amp so would not be able to be connected directly to the in/out of the radial circuit as it passes through (i.e. as you would if just installing in a bunch of sockets). Also, since I guess they themselves are classed as devices shouldn't they have an isolating switch also?
I worry that there's no safe way to install these devices, what are your thoughts? Is jointing using Waygo's and feeding the controllers from those also safer and allowed?
Graham
Connect the 8A ones using FCU's and fuse them appropriately. The 13A ones will be OK in normal 13A sockets.You don't need Isolating switches for the devices.
Thanks @jj4091 . The concern is that even the 13 amp ones, the terminals don't seem man enough to cope with anything over 13 amps, if wired as part of a 20 amp radial could the terminals get too hot if they're being used to connect between the cable segments for the circuit and its running close to capacity?
I mean the devices plugged in shouldn't be drawing anywhere near that much unless something goes wrong but with 3d printers that's a distinct possibility!
