Yes, because, if that happens, the 'electrician' is lying but it should not get that far.maybe the big question is, if a Part-P is issued, should i or can i query it ?
You are correct. I had missed that. So yes the guy has to rip it out and start again.As already said if blanking plates are fitted then not really a problem. .
Theres Horizontal cables as well as vertical ones
I'm a bit confused here, because I would have said the same as eric said in the first place. Yes, there are horizontal cables, but AFAICS they all arise from the sides of backboxes - so, if those boxes (containing joints) were covered with blank plates (which remained visible) then I would have thought that the cables would all be within safe zones ... or do you (rocky) not believe that joints behind a blank plate (as opposed to more 'obvious' accessories) create a safe zone?You are correct. I had missed that. So yes the guy has to rip it out and start again.Theres Horizontal cables as well as vertical onesAs already said if blanking plates are fitted then not really a problem. .
... if those boxes (containing joints) were covered with blank plates (which remained visible) then I would have thought that the cables would all be within safe zones ...
That's quite possibly true, although I assumed that eric was also thinking of them remaining visible (even if not very pretty) - since one can't really tile over standard blank plates!You're correct John. I think the point is, it's over a kitchen worktop, so likely to be tiled or some sort of splash-back fitted, ergo not likely to remain visible.... if those boxes (containing joints) were covered with blank plates (which remained visible) then I would have thought that the cables would all be within safe zones ...
Welcome to the clubYes, sorry john and eric, got a bit confused yet again
