I have been musing, especially as the Scottish Islands have 17,000 people without power in the middle of the winter...
I have a dozen solar panels on the roof of my house and they are capable of generating a couple of kilowatts. As I understand it, the inverter will not supply any 240Vac until it has got itself synchronised with the mains (good idea!!). When there's a powercut, the inverter will not provide any 240Vac at all. Would it be possible to isolate the grid at the main switch in the CU and, using a length of flex with a three pin plugtop on each end (I know, I know...) plug a cheap 12V inverter into a socket. The cheap inverter could run from a 12V battery (I have alarm batteries) and this would provide a crappy 240Vac signal for the solar inverter to synchronise. I'd then have upto a couple of kilowatts (on a good day) from an alarm battery!! Enough to run the gas boiler and the fridge-freezer...
My main concern is that the solar inverter will produce a voltage higher than the pseudo-mains coming from the cheap inverter and this might kill the latter. There's also the question of whether the solar inverter will sync to the cheapy at all.
Any thoughts?
Any thoughts?
