Can anyone suggest a source for individual compression springs? I'm after a couple that will fit on m6 or m8 threaded rod, around 200N for complete compression, and 30 to 40mm long.
Curiously enough, check out the RS Components website - the leading electronics supplier.
I believe the spring strength is measured in N/mm so you should find something there.
John
In the end I ordered from Ashfield Springs. Much easier to find the specification I wanted, no minimum order or quantity, and effectively delivered before 1pm next day.
