- Joined
- 13 Sep 2015
- Messages
- 114
- Reaction score
- 6
- Country
I have a 10mm cable, fed from a dedicated 45 RCBO in my consumer unit, feeding my current range cooker. Everything (mains incomer, consumer unit, all internal wiring) done in 2012.
SWMBO has redesigned the kitchen. She has ordained that we shall have a 16 amp rated oven; a separate 13 amp rated oven; a warming drawer rated at about 4 amps; a gas hob with whatever small feed it needs to make the piezo spark lighters work.
She has further ordained that all of the above will be routed through a grid switch array; one switch per appliance.
Three material things:
(1) GAFAIK, grid switches are rated at a maximum of 20 amps.
(2) I don't fancy trying to manoeuvre 10mm cable around to feed all of these things.
(3) I don't fancy unplastering and decarpeting my house to rip lots of wiring out and start again.
So, basically, I need to find a gizmo that will enable me to take the 10mm 45 amp feed, fuse it down five ways with 5 20amp (or 16 amp) fuses, so that I can then run 2.5mm cable from there to each grid switch then appliance.
Best I can come up with is a small 'garage style' consumer unit, 10mm to main switch, 20 amp MCBs.
Anyone got a better answer? Sticking a slave consumer unit in the kitchen is a bit of a butt ugly answer and this can't be that uncommon a scenario ...
James
James
