OP you are claiming to be a trainee/ apprentice
This is basic stuff you should know
YOUR health and safety as well as Wiring Regulations. If you ignore those , it’s only your house and your family. What could possibly go wrong?
RCDs have been required for most socket outlets since 1991. Even before that RCDs were required in some circumstances and were often installed anyway.I guess there must've been a time when there weren't any regs on this and it was okay to do.
Whatch an episode of only fools and horses.how do you think you'll do it?
Well before I was born, 72 now, there are some dates when major changes were made, 1966 earths to lights, 2008 RCD's on nearly everything. And each edition has a date on which designs must follow the new bits, note design, not date of installation, however the PIR/EICR has dropped the "does not comply with current regulations" as unhelpful, and now we have the prospective dangerous.
This can the incorporate changes, so if a installation was designed to use tungsten bulbs, and now uses LED then maybe using a type AC RCD is no longer and good, and it needs type A. I am not saying that is the case, but trying to point out why changes are required.
Things have changed over time, when I did my apprenticeship there were no smart switches, bulbs, or relays, even back 10 years, and we did not have the smart lamps of today, so lighting a kitchen with 16 down lights, was not really a problem, but today 16 colour changing smart bulbs would be expensive, so likely we would look for a system with less bulbs.
I find we tend to add on to a system, so much depends on what one already have.
That consumer unit has a date of 1998 on it, which is very likely when it was installed - in which case it did not comply when installed.
The missing blank on the front needs to be replaced, as there are exposed live parts just inside that opening.
I don't want to be mean but -
Why have you started on year two when you do not seem to know even the basics?
Are you starting with a completely blank sheet never having done any electrical work at all before?
It’s the equivalent of a heart&lung transplant for your electrical system. If all the cabling, sockets, switches etc are all kosher then it’s not too tricky. The basic way is to do some testing and inspection first. Then fix any issues, then install the new consumer unit.Is it a big job to get an RCD CU put in ?
What is this specific course, how long is it, and who is offering it?The course only offered from level 2. If you have A levels in anything else. You don't need to do level 1. Level 1 and 2 are similar they say.
Everything.What has this got to do with spotlights mate?
Why are you thinking of putting "spot lights" in a BEDROOM?I'm thinking of putting 4 spotlights in a bedroom on 1st floor which has a bedroom attic above it...
