B
breezer
thats as may be but the idea in life is to prevent accidents not cause thm by spuring off a 6mm cable with a 1.5 mm cable
DNOs do this all the time - the main supply cable for a house isn't fused at the point where it leaves the feed cable. it's fused at the end - in the cutout. the cable is still overload protected, and this isn't dangerous!!
crafty1289 said:56565, put it this way. Where this 1.5mm cable enters the FCU, what if, by some rare chance, a fault occurs before the fuse, that causes 32A to flow along the 1.5mm, which is only designed for about 15-20A? The MCB will not trip. The cable will melt and may create a fire, before the MCB trips. Even less chance if its protected by a rewireable. Therefore, it should be done in 6mm cable, like the rest of the circuit. Then if such a fault occurs, the MCB will trip before the house catches fire, and more current can, theoretically, flow, so it will trip quicker.
a cable in a house is more likely to be damaged than an overhead cable.
what also if the end user (not this poster) over loads the 1mm cable.
what if, by some rare chance, a fault occurs before the fuse..
what if someone comes along..
You cant compare this with things the REC do..
http://205.243.100.155/frames/longarc.htm has a higher resoloution version along with some others.breezer said:user56565 isn't dangerous ? click here
(just been off finding it)
it may take a second or two to downlaod, and for clatity, its a substaion transformer
user56565 said:haha very funny breezer!
stupidity springs to mind (it wasnt me who laughed at a sub station blowing up)user56565 said:you can only say it's dangerous if you can prove/argue why.
and you haven't exactly been able to make any valid arguments against my points!
"...click here" suggests that i personally contributed to that particular clip. so your post comes across as a joke.user56565 isn't dangerous ? click here
its like holding a pointed gun to your head, it will go off but when
