- Joined
- 12 May 2007
- Messages
- 292
- Reaction score
- 2
- Country
I ha a double socket on the wall in yhe kitchen. i am running a spur under the worktop a into a kitchen base unit. does the single socket in the cupboard need to be fused?
It will be - by the fuse in the plug.does the single socket in the cupboard need to be fused?
A spurred spur, will have two sets of cables at the outlet it is spurred from. So the first thing to find out, is what type of circuit you have and if it is a ring final, then establish the integrity of the ring, at the outlet you wish to take the spur from.this is not a spur off of a spur. the double socket has 2 cables, 1 in from the last socket and 1 out to the next socket. the spur for washing machine is planned to come off this double socket
That is fine then, no fused spurs required to extend or spur on to the circuit.its a radial circuit
