No, if you use fine grit just to take the tiny knobbles off, I would expect one coat of stain to be enough.If I start to sand and smooth I am going to need to put quite a few coats again ?
Yes. You would probably get away with 400 grit though, if you eventually wax or varnish the banister. Do not sand through the stain; just flatten the tiny imperfections in the surface at the moment. Gentle hand rubbing, that's all.Is 240 grit too harsh
I don't know much about varnish, as I tend to wax everything. Certainly a lot of people swear by poly. Maybe someone else will chime in.What varnish you recommend for this? Is POLYURETHANE the best for this?
