Well you blatanly can't.... "You can`t have two circuits on one fuse!" is one.
I thought that one was atually in the regs at one point, or possibly OSG"A connection inside a metal enclosure must be bolted down securely and not left floating!" is another.
When I rewired my home in early 80's I advised I was breaking the seals and moving the meter to a temporary position for timber/damp treatment. As requested I let them know when I was done, they sent out an inspector with his tickbox sheet, several thing caused him problems such as:then you get the ordinary person totally misquoting a comment such as
"This cable only needs to be 2.5 but it has been done using 4.0 conductors" then becomes misquoted to "The inspector says the wrong cable has bee use so we have to rewire it all!"
I used singles in steel tube and trunking so I didn't sleeve the earth wires, additionally I didn't use capping,
I'd used yellow 16mm² for the main bonding and added green marker tape - his sheet had no mention of the colour so that wasn't an issue but it did state 10mm²,
I'd used 4mm² for the 15A power circuits & 30A rings,
I'd positioned the meter higher up the wall and the CU's off to one side - I ran the tails in trunking to tidy/add protection form the predicted detritus generated by a young family as this was in the cupboard under the stairs (I did conceed that point and removed the trunking for him)
