I was given a BR 400 which had been well used but ran even after storage (with fuel!) for 2 years by a retired gardener.
Last winter it stopped running and I took it to an approved Stihl dealer for a service. Since then it's been used only a handful of times and has started impeccably.
Now I have deja vu, just as the leaves are falling this happens...
It starts cold, on idle after 2 pulls as normal and I use it for perhaps 20min happily. Then I hear it start to struggle a bit, lower revs and a bit uneven. I find that reducing the throttle a little helps, but a minute later the same. Over about 5 minutes this went round and round until all it would do is idle or struggle terribly - then it died. I restarted it easily but even on idle you could hear it slowing like a dying grandma until it stopped.
I am an engine noob with some basic knowledge but am guessing it's either related to air or fuel. Since it was serviced I've been using the Stihl pre-mixed non-ethanol fuel to avoid problems!
I have tools, are there any easy steps/tests I can do to see if it's an easy fix for losing it right when I need it (again)? Do the symptoms I describe suggest a particular problem?
Many thanks.
Many thanks.
