The problem with all this kind of activity is that it is totally unpredictable irrespective of "doing the homework", i.e. it is not investing it is gambling. People like Warren Buffet do not do it for that very reason.
Speaks a man who hasn't tried.
Of course it's gambling, but it isn't entirely unpredictable. It's about as predictable as the height of the water on the harbour wall.
It's absolutely predictable in that it goes up and down a lot.....
Do you think I plucked AMC and BBIG out of thin air?
I do find the whole way the money washes around with people trying to make money out of money, unsatisfactory, like I find gambling on houses unsatisfactory, but it's the way the world works. I already proposed one way where it works out all bad. Quite soon it'll be entirely AI driven - many outcomes from that are possible.
Yes I know about bullish buramis and descending hawks, tthe support and resistance levels, and half a dozen other "indicators". There's no magic about it, some help a lot, others not.
YOu don't even need indicators. You can just watch the price and the clock.. The volume helps.
Here's a randomish bit of chart from HSBC.
You buy when it turns blue for a couple of bars, and sell when it turns red for a couple. Ignore a single if it's the "other" direction.
You can make money out of the descending, if you "sell short", but many don't bother.
YOu can be a little more sophisticated to refine the technique, but it works pretty well.
If you look at a finer timing on the change for example, then you don't "lose" a whole bar. All these bars are 4 hours wide - plenty of time. You can use daily ones, and juspend half an hour od half a dozen stocks once a day. It doesn't make much difference.
You put in "stop losses" so if it collapses when you aren't there it catches .
Bottom to top of this is about 7%
This is a couple of months. You would get about 5% out of the rising bits, even though there's almost no overall rise.
WHere else are you going to get 5% interest in 2 months.? A kid could do it. When you get to 10%, take 5% out and put it under the mattress, in case there's a tsunami.
